  #110 (permalink)
Old 10-21-2015, 10:11 AM
SPF1061's Avatar
SPF1061 SPF1061 is offline
Cobra Make, Engine: Superformance Mk III / Windsor platform
Originally Posted by Ace23 View Post
While this is always an option I think the more important issue is why we would not be seeing any voltage at the choke. Once we correct the voltage issue I will set the choke but completely removing it isn't off the table either.
Ace23,
If the carb on your car has a choke, it is not truly a full on high performance carb. Everything else being equal, there is power to be had from a carburetor with smooth throttle bores and no choke. Not saying this is the sole answer to all of your performance issues, but if you are really trying to squeeze the max potential out of your motor, this should not be overlooked.
