The rear end is solid mounted now, top to bottom. The bigger hub/bearing may not matter as the outside bearing is still on the inside of the rim mount. It would be better if the bearing were on the outside of the wheel moumt, like a front hub. I guess The bottom line is to check and re check if you thrash your cobra with a high hp motor. Cranky, I will be at road america in september. scott
