Thread: Overheating?
  #31 (permalink)
Old 10-21-2015, 04:03 PM
DanEC's Avatar
DanEC DanEC is offline
Good luck. No promises, but since you have vacuum advance there's a good chance changing it over to manifold vacuum could make a noticeable difference in engine temps in traffic, at idle and slow to moderate speeds. It's an easy to do change also. If your engine is a bit weak and lumpy at idle, as Cycleguy55 mentioned it will also smooth that out a little due to the greater timing advance and make normal starts from a stop a bit easier.
ERA 782 Running
