Originally Posted by Jaydee
I asked my engineer and he said it should be fine to fit an dash adjuster. I'm not going to bother fitting one. Even still. The bar can still drift sideways even if you use locknuts. The rose joint inside the brake pedal sleeve is free to move side to side.
JD
Some states require that the balance bar be made non adjustable (welded) after the certifying engineer is satisfied with the brake bias.
