Newest Problem
Screwy handling was a result of the passenger side rear wheel being loose; wheel bearing at 7k miles...Also noticed both rear wheels are coated in grease inside the rims...Guess I'll be doing both.
Also need to figure out the apparent defect in the way the bearings are mounted which results in them throwing grease and failing at 7k miles...
Hardest part seems to be figuring out all the parts and how to modify them to work together and hopefully cure whats causing them to fail.
Hub is a 99-04 mustang cobra, bearing is the same, with a super coupe nut.
Superformance 1764
Ford Racing 427 SB
