Originally Posted by snakesaway
Well the temp test was interesting found about 30 degrees difference on the drivers side head at the back of the heads (this is the side I suspect the gasket is the wrong way around) but not much difference at the front of the heads.
snakesaway
I put the gauge temp sender at the rear of the intake manifold at some stage and found the gauge read low. Very little heat regardless of driving. Moved the sender back to the usual place (front right) and temp was all back to normal.
Geof
