Originally Posted by DanMartin
Make sure you don't have an air pocket that is keeping the sensor out of the coolant flow. I had that and the readings were spurious.
There are several ways to 'burp' the system....if you need more detail you can search for it on this forum.
Thank you for this recommendation. I did remove the expansion tank cap the other and let the car through several cycles. Many air bubbles did come out. I will search the form for the "burp" the system thread.
Jamie
