If you just want the lips kicked up a notch, use some Mothers Mag & Aluminum polish. Runs about 9 bucks. You can use sparingly, hand polish with paper towels if you like, then give it a second round with a soft cloth. Should shine up to a mirror finish. If you need to take down and machine marks, 800 grit with a little water and light pressure will softly take out the marks, then follow up with 1000. The alum polish will take out the marks from there. I'm restoring my stock Ford 20's right now, and it works killer!!
Good luck,
Mike.
"It's not about getting from point A to point B. It is the point"
-J. James
M. Krause
1.508.944.3368
