Thread: Mc leod
Old 11-03-2015, 10:49 PM
Blacklemming Blacklemming is offline
From summit,
Email
Overview
Applications
Required Parts
Suggested Parts
Show All
Brand:McLeod Racing
Manufacturer's Part Number: 512957
Part Type:Manual Transmissions
Product Line:McLeod Musclecar 5 Manual Transmissions
Summit Racing Part Number:MCL-512957
Number of Gears: Five
Input Shaft Diameter: 1.125 in.
Input Spline Quantity: 26
Output Shaft Spline Quantity: 32
Bellhousing Included: No
Yoke Style: Slip-on
Yoke Included: No
Shifter Included: Yes
First Gear Ratio: 2.95:1
Second Gear Ratio: 1.99:1
Third Gear Ratio: 1.34:1
Fourth Gear Ratio: 1.00:1
Fifth Gear Ratio: 0.63:1
Case Material: Cast aluminum
Quantity: Sold individually.
In-Store Pickup:Choose In-store pick-up (OH, GA, NV) on our web site.
CalculatorGear Ratio Calculator
ToolTransmission Lookup
The revolutionary and innovative design of McLeod Musclecar 5 manual transmissions gives musclecar owners the ability to use an overdrive tranny without expensive or annoying modifications. They feature an exclusive case design that allows for fitment into tight tunnels. Gone are the days of cutting your floorboards to be able to get the benefits of improved fuel economy and the lower rpm that an overdrive transmission provides. With 8620 forged steel gears and a 32-spline output shaft, the McLeod Musclecar 5 manual transmissions can handle up to 500 ft.-lbs. of torque. The gears are fully synchronized for smooth shifting and quiet operation, while the internal rail shifter aides in quick and smooth shifts--and the front cover is designed to bolt right up to your factory bellhousing.
Warranty
Some parts are not legal for sale or use in California on any pollution-controlled motor vehicles
Back to Results
