Old 11-04-2015, 11:52 AM
Akimbeau Akimbeau is offline
Cobra Make, Engine: ERA 289 FIA 351Windsor
Hey guys! Thanks for your feed back!
LHM...These are photos supplied by the seller. He received the project 5+ years ago from someone who owed his company money. It's been sitting a while as you can see. Not much info on the build. The seller said the frame was built for a T-Bird IRS and it currently as a 8.5 diff with axles but little else as far as suspension.
Bill...No way to know if the frame was being built to fit the cobra body that comes with it. The project is a 60 min drive away so I wanted to gather enough info to make it worth going to see. You're right that it looks like a nicely built frame...I've not seen anything like it either...a Bennett frame is the closest I've seen that's similar and its only vaguely similar.
Kim
