Thread: Clutch problem
Old 11-06-2015, 04:22 PM
Snakebit's Avatar
Snakebit Snakebit is offline
Club Cobra Member
Cobra Make, Engine: ERA 289 FIA #2100 Rio Red Wimbledon White Stripes 302 stroked to 331 Webers Richmond Road Race 5 speed
Default Clutch problem
The clutch in my ERA has an external hydraulic slave cylinder pushing on the clutch fork with a standard throw out bearing. With the engine off, I can push on the clutch pedal and shift the gears. The slave cylinder works and moves the clutch release fork. When the engine is running, I can push on the clutch pedal, but it will not shift into gear, the trans will grind. What is not releasing?
Snakebit
