Originally Posted by Texasdoc
Is there any reason I can't use those $10 glass filters from Mr. Gasket that I can get at O'Reilly as a pre-filter? They say "Not for use with EFI" but I'm thinking that means "post-pump" due to the higher pressure. In a pre-filter setting there is no pressure, only a small amount of vacuum that will vary depending on how dirty the filter actually is.
Those don't have the surface area or the micron rating for use as a pre-filter. I like and use Aeromotive 100 micron pre-filter and 10 micron post-filter.
