Mcleod hydraulic TO-bearing will leak, thats why they come with new o-rings right in the box to rebuild it after a couple of
oil changes. I like the ford bearing and fork, with a custom bracket (2" angle iron with a couple of holes in it) to mount a hydraulic slave cylinder. If it leaks, at least it's on the outside of the bellhousing. You must adjust the ball stud on the bellhousing to get the geometry right. If you want a complete setup, call House of Cobras and talk to Don, the parts guy, he'll sell you the whole setup.
