  #46 (permalink)
Old 11-12-2015, 10:14 AM
lippy lippy is offline
Originally Posted by A98Coupe View Post
Lippy,
I just picked up theis thread after doing some researching to solve similar problems to yours. I have just installed a new 468 shelby stroker with dual quads and a fairly large cam/overlap. Runs fine under load, but surges like hell below 2,500rpm, part throttle cruise and runs-on after ignition off. I am considering to get a wideband to help me tune the carb, but your point about increasing the initial timing is interesting. I'm at around 15degrees initial and 36 Total.
Did you solve the run-on problem by increasing the initial advance or something else?
Thanks
Stuart
If your plugs are wet try the bigger bushing and bump your full advance a bit. Pm me if you'd like to chat.
