Along with my Kwik Lift, I have the optional casters that position under each leg. That raises the car an additional couple of inches, but more importantly allows me to easily push the car around in the garage. I can roll it easily by hand to position the car over the floor drain to wash it, or I can push it outside into the driveway if I want to work outside. If I align the sidewall of the left front tire with the v-groove in the left ramp, I can pull onto the lift accurately to the same place every time. The car is then supported very solidly and safely. I once used my lift to work under my son's 5300# pickup truck without problem, though I would not recommend exceeding the weight rating of the lift.
When I said I wanted to be somebody, I probably should have been more specific...
