  #131 (permalink)
Old 11-14-2015, 10:34 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Well, maybe....
A Roush 427R is basically a Dart block, aluminum heads that flow somewhere around 300 cfm, a hydraulic roller cam, a Victor Jr. intake, and a carb. ---, Roush rates their 427R at 550 hp.
Logically speaking, the displacement is the same, but factory FE head/intake parts are not on the same platform as modern SBF parts, and that's where the difference lies.
Not saying you're wrong, but I think there's a discrepancy somewhere that is being left out. No way a factory 427 will beat a new Roush 427 R (or any 427 Windsor by any manufacturer) by 30-50 hp.
Well, a factory 1964 FE crate motor did beat out a modern roush crate 427R, so I guess you are wrong.
Long before Roush and you were building crate motors, Ford was, and around 1964-65 Ford offered a crate 427 Hi-Riser , dual plane, single four barrel I believe rated at 485hp. Don't forget, NASCAR banned Hi-Riser heads from racing. I built my engine to replicate this crate motor.
I built my motor to replicate this engine, with an original intake from 1964, original Holley carb that came on that motor, and original pattern aluminum 1964 Hi-Riser heads from Dove. 1968 427 service block bored 0.017" over, cast crank. Actually, I believe there was literature from Shelby that you could have gotten this motor as an option for your 427 cobra, although I'm not sure how many, if any did, although I know a couple cobra's came from Shelby with Hi-Riser heads.
So, my 1964'ish Ford crate 427 did out perform a modern Roush 427R motor. I guess the Ford engineers back then knew a little?
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
