Dual Fans
I purchased a used set of fans from someone on one of the forums. When they arrived, the fan blades look to be bent slightly. Any suggestions? Do you sell just the blades? Should I try to form them myself (don't like that idea). Also, what are your suggestions for mounting the fans. My B&B radiator has two holes on each side that I could run a long rod through a metal tube and attach it to the cross bars. WIll this work?
