Old 05-04-2002, 03:27 AM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
Horsepower to Go !
Prices for brand-new, dyno-tested engines - complete from carb to pan!
Call for detailed parts list and dyno results !
Super 502 - 800hp / 670 ft-lbs
$11,445 Delivered!*
4.47" bore x 4.00" stroke, Gen VI block with siamesed cylinders, 4-bolt caps, RMRE/Brodix -2Plus rectangular port heads, 2.250" x 1.880" stainless valves, 1.625" Vasco springs, Apollo Trick Titanium retainers, RMRE valvetrain stabilizer, ARP 12-pt head studs, forged steel crank, custom 14:1 forged pistons, RMRE/Manley forged +.250" H-beam rods, RMRE custom ground roller cam, aluminum rockers, double roller timing chain, ATI damper, Edelbrock intake, RMRE/Gary Williams Holley 1050 Dominator, Mallory distributor, RMRE/Moroso wires, and RMRE lubrication system.
Super 522 - 845hp / 680 ft-lbs
$12,745 Delivered!*
4.56" bore x 4.00" stroke, Dart Big 'M' block with siamesed cylinders, 4-bolt caps, RMRE/Brodix -2Xtra rectangular port heads, 2.300" x 1.880" stainless valves, 1.625" Vasco springs, Apollo Trick Titanium retainers, RMRE valvetrain stabilizer, ARP 12-pt. head studs, forged steel crank, custom RMRE 14:1 pistons, backcut .043" rings, RMRE/Manley forged +.400" H-beam rods, RMRE custom ground roller cam, aluminum rockers, double roller timing chain, ATI damper, Edelbrock intake, RMRE/Gary Williams Holley 1050 Dominator, Mallory distributor, RMRE preferred lubrication system.
Super 555 - 910hp / 750 ft-lbs
$14,445 Delivered!*
4.56" bore x 4.25" stroke, Dart Big 'M' block with siamesed cylinders, 4-bolt caps, RMRE/Dart Pro 1 355 CNC heads w/ RMRE porting, 2.300" x 1.880" stainless valves, 1.625" Vasco springs, Apollo Trick Titanium retainers, custom-coated Clevite H-Series engine bearings, copper head gaskets w/ O-rings, RMRE valvetrain stabilizer, ARP 12-pt. head studs, Callies 4340 forged crank, custom RMRE 14.5:1 pistons, backcut .043" rings, RMRE/Manley forged +.400" H-beam rods, RMRE custom ground roller cam, aluminum rockers, double roller timing chain, ATI damper, Edelbrock intake, RMRE/Gary Williams Holley 1150 Dominator, Mallory distributor, RMRE lubrication system.
Super Chief 565 - 1035hp / 815 ft-lbs
$20,995 Delivered!*
4.60" bore x 4.25" stroke, Dart Big 'M' block with siamesed cylinders, 4-bolt caps, RMRE/Dart 18° Big Chief heads w/ RMRE porting, 2.400" x 1.900" titanium valves, 1.625" Vasco springs, Apollo Trick Titanium retainers, custom-coated Clevite H-Series engine bearings, shaft-mounted rocker system, Jesel belt drive system, copper head gaskets w/ O-rings, ARP 12-pt. head studs, Callies 4340 forged crank, custom RMRE 14:1 pistons, backcut .043" rings, RMRE/Manley forged +.400" H-beam rods, RMRE custom ground roller cam, ATI damper, Dart Big Chief intake, RMRE/Gary Williams Holley 1150 Dominator, Mallory distributor, RMRE preferred lubrication system.
30th Anniversary 572 - 1100hp / 839 ft-lbs.
$26,495 Delivered*
To celebrate our 30th Anniversary, Reher-Morrison has put the results of constant R&D, Pro Stock technology and racing engine building knowledge into an engine that is the most technically advanced Bracket Racing Engine on the market! The 30th Anniversary Super Series 572 has many special features, including a DART Big 'M' block, Gas ported Reher-Morrison Custom designed 4.625" Bore pistons, Offset lifter bore sleeves with offset T&D Shaft rocker arms, Custom Reher-Morrison 7/4 swap roller camshaft, Reher-Morrison/DART 14° Oval port CNC Big Chief heads, and Reher-Morrison vacuum pump assembly. It produces 1100 HP and 839 ft./lbs of Torque. Just imagine how your car will perform with this awesome Horsepower and Torque curve! This is Pro Stock Technology for you!
Super 622 - 1280hp / 950 ft-lbs
$34,995 Delivered*
4.625" bore x 4.625" stroke, Dart Big 'M' Tall Deck block, 4-bolt caps, Gary Williams flow matched 1150 Dominator Carbs, RFE Spreadport Intake, RMRE Billet Rail Sheetmetal Valve Covers, RMRE/Dart 14° Big Chief CNC Oval Port Heads, Comp Cams Triple Valve Springs, 10° Titanium Retainers, Shaft-Mounted Rocker Arms, IRC Tapered Pushrods, Crower Cutaway Roller Lifters, RMRE Custom Ground 7/4 Firing Order Swap Camshaft, RMRE Gas Ported 4.625" Custom Pistons, RMRE/Total Seal Rings, .043BC/ .043 / 3/16, C&A 6.750" Speedway Rods, Callies 4340 4.625" Crank, Jesel Belt Drive, Mallory Crank Trigger Kit & Distributor, RMRE/Moroso Custom Spark Plug Wires, RM Dry Sump Kit, RM Vacuum Pump Kit, ATI Damper (SFI Approved), Dart Head Stud Kit
Reher-Morrison Racing Engines, 2002
web@rehermorrison.com
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
