Old 11-17-2015, 12:51 PM
stephen low's Avatar
stephen low stephen low is offline
Neutral
The build inadvertently started with both a 3/4 master and slave. That took two legs to depress the pedal just!
Replaced the slave with a 7/8th and to now get this strong pedal. Whether an increment jump again to 1" of 1 1/8th is probably the question.
Pedal already has 5:1 ratio and I can't play further with the ratio, clutch fork is 1.56:1.
What sort of fork travel at the thrust bearing is usually need to release a clutch?
slowy
