Old 05-04-2002, 04:34 PM
OhBuoy OhBuoy is offline
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Send a message via AIM to OhBuoy
Default Starter does not spin
I have gotten to the point where I have disconnected the coil wire and am ready to hear the engine turn. I wired everything up, and when I turn the starter, nothing. I tried the old electritions trick of drawing a ground to the starter lead to see if power is getting their, and there were lots of sparks. Sparks = power. So, what gives? I am pretty sure my engine grounds are good, but will double check. Any other thoughts. The starter I had came with a two lead wire, and I replaced it with one with just the power lead. THere are three lugs on the back of the starter. Does one of these need to be connected to the starter switch possible (second solenoid?).
