spent a couple of hours mounting the rear sway bar this arvo i had to modify the plates the bearing carriers mount on as the holes didnt line up . updated carriers with different bolt patten ten minuites with a die grinder had it sorted and ive let pace know all mounting plates supplied now will be the correct ones no big deal just had me scratching my head for a few mins and gave me splinters.
apart from that all went together quite well i just need to drill and tap a hole on each top wishbone where a bracket bolts too and thats one job crossed off the list on the whiteboard tomorrow hopefully will see the hole cut out of the firewall for the pedal box then i will start with the insulation and brake and fuel lines ..
some pics of todays effort
a cobra is a passion anything else is just a car
i dont care what the question is .. The answer is more power!!!
