Originally Posted by ERA2076
Oil Lite Bronze
I absolutely
DON'T RECOMMEND this. It's putting a nasty bending moment into the arm and lower pivot shaft. As the suspension goes through its travel, the arms don't remain perpendicular to the hub carrier. Some compliance is necessary.
If you want "solid" on the outer end, use rod ends or spherical bearings.
