Here's measurement information from Tire Rack, including the following note: "When measuring a 5-lug wheel the measurement is only an estimate unless accurately measured using a bolt pattern gauge. A bolt pattern gauge is a specialty tool and is not widely available."
https://www.tirerack.com/wheels/tech....jsp?techid=92
Here's another view on this: "If your wheel has a 5-bolt pattern, measure from the BACK of one bolt hole to the center of the second bolt hole as shown in the diagram. You can also measure from the CENTER of one bolt hole to the CENTER of the third hole using a multiplier of 1.05 to find your bolt circle."
There's an illustration of this at the following link:
http://www.wildhorses4x4.com/product...terns/tech_faq
