I wouldnt pre-order in case there is a difference - usually a Cobra/King Cobra (M7560C302) setup will work - the key here is that your spline **** on your 3550 input - 10 spline or 26 spline --
also - verify your clutch hardware (bolts attaching the clutch cover to the flywheel ) are good bolts ( ARP ) and that all is good back there - usually we recommend the surfacing ( refinishing ) of the flywheel at this time. -
