Thread: Hood scoop
Old 12-16-2015, 03:35 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Fella,
Tom's red scoop is about dead on, you OR your fiberglass guy is going to split the scoop dead center from front to less than a 1/4"
To the back. Use the DOOR CUT OUTS for filler, cut strips out to match your new configuration. Each strip will be cut in a pie shape
Making the hood as TALL & WIDE AS YOU NEED IT. Cut the BOTTOM OF the original scoop flush with the surface of the hood.
MARGLASS/ DURAGLASS the pieces in place, once you've got it the way you want them, reinforce it IN OUT with MATT.
Body work ' then prime etc.
DV
