Radiator Bracket
I modified my bracket incase I needed to remove the radiator. I cut the bottom support off and then reattached it using a piece of 1" aluminum angle. One other Mod I wish I had done was to of had a drain welded into the bottom of the tank so you wouldn't have to remove the lower hose. If you haven't bought a radiator you can call Howe Racing and they will do that Mod in house for you.
The floor of the A&C is thick 1/4-3/8" and you seat tracks can be secured to it using fender washers.....
One other suggestion; don't use a Panhard Bar, you have a triangulated 4 line and it will cause bind!
Jon
The Impossible Only Takes A Little Longer
