Old 12-17-2015, 09:17 AM
olddog olddog is offline
Does it have an inner-cooler? (not sure the spelling)
Were larger fuel injectors installed?
Has the ECU been re-tuned correctly?
How much boost is it set up for?
I can tell you that if they push much boost, it will need bigger injectors, bigger fuel pump at some point, and bigger fuel lines possibly. The timing has to be backed off as boost goes up, as well. The point being that the ECU has to be set up properly.
