Phil,
I purchased the items in the attached picture for $30 on eBay. This includes all the original bolts and the pink aluminum spacer. On the attached image, I have included the Ford engineering part numbers for upper and lower bracket to be used without a smog pump. I figured my Cobra will not require one.
Search using these part numbers and you will be amazed.
![Name: 20151221_160116[1].jpg
Size: 82.4 KB](http://www.clubcobra.com/forums/attachments/all-cobra-talk/26985d1450735870-fe427-oem-alternator-mounting-brackets-20151221_160116-1-.jpg)
