  #189 (permalink)
Old 12-21-2015, 07:08 PM
Ace23 Ace23 is offline
Cobra Make, Engine: SPF#1867 , KC427
Originally Posted by madmaxx View Post
You have to way the risk. Working over the fenders or lifitning. Just make sure you protect your paint. If you pull I would strongly suggest you rear main seal is perfect and not leaking as this would be the time to replace. I assume you can just lay the headers to the side, getting the drivers out is a little tricky. If someone has done it before than they will know the path of least resistance.
Perry prefers to pull the transmission out through the interior so you can just lift the motor straight out. The main seal and a few other things are definelty on the table due to the motor being out. The car is 12 years old so I will probably look at replacing some of the hoses as well.
