12-24-2015, 04:45 PM
Cobra Make, Engine: Superformance, 351W stroked to 396
Thanks for the helpful advice. This is a great forum.
Originally Posted by Blas
As was mentioned earlier, the rear shock mounts would be the first thing I would look at. The early MKIII's have survived the test of time quite well, but as with all fiberglass cars, grounding points for the wiring are a problematic area. A summers afternoon project would be to locate and clean up all the major grounding lugs on the car. Another must do project is the addition of a master fuse on the car, something the early cars did not come with from the factory. A battery cut-off switch is also another great addition on the car. Lap belts and shoulder harnesses are most likely out dated, but unless they look frayed or slick they probably pose little concern. An under car and hood inspection of nuts and bolts, including torquing the rear suspension bolts is time well spent. Don't fix it till it's broken is a good rule of thumb.Drive the car before changing things. But wait, do you have winter up there in Canada? I forgot about that. Waxing in a heated garage might be the closest you get to putting miles on it at the moment. ENJOY and welcome to the madness!
