Kirby,
I'd bet money that the wires to the turn signals are switched with either the front or rear marker lights.
There are 2 different elements in each bulb. They are not the same. If you get them switched, you can get the symptoms you describe. Check both your right front and your right rear. Either or both of them could be the problem (front or rear). The connection pad that the bulbs contacts can get pushed in and rotated 180 degrees and therefore be switched. One element burns brighter than the other. The one that burns brighter is for the turn signal on the one set and the brake lamp on the other set. The ones that burn dimmer is for the Parking lights.
Hope this helps - Okiesnake
