I have fitted out my workshop with adjustable shelving that each unit is 2.7 long and 2.4 high. Each adjustable shelf will hold 200kg.
As far as benches go I have adjusted the first shelf as low as it will go, the second is at 900mm and have the top two high up giving a good work space with storage below and above.
I have fitted 1x 36w fluros to the underside of the third shelf for working light
Powered by Cu
