Originally Posted by indianamoon
Mike,
Consider putting a "T" at the outlet down low with a vertical leg and valve at the bottom to drain off the condensate. We also always come off the top of the high run and then a couple of elbows down to keep the condensate spray in check.
Agree with Indianamoon. Drip legs at the low spots and a good filter / dryer setup at the compressor outlet....
