  #131 (permalink)
Old 01-13-2016, 02:31 PM
07cob's Avatar
07cob 07cob is offline
Slowly working out tooling for the new mill. The Hafco mill uses an NT30 taper for the tools. The CNC mill has an R8 taper which means most of my old tooling is not compatible with the new mill... Bugger.
Mike
Can you get an adapter for the NT30 to R8? It will take up some vertical travel but you should have plenty for most jobs. At least you might be able to reuse some of your old tools. Not sure if it would work with the fancy schmancy new fandangled tool changer.
Geof
