Old 01-15-2016, 09:17 AM
Large Arbor Large Arbor is offline
Cobra Make, Engine: ERA 714
Thanks Dan. I am hoping for similar results, although my block is aluminum. So if I read your post correctly, you gradually loosened the rocker shaft until you could completely remove and then gradually hand tightened and then torqued down to spec. Was there any tolerances that you checked or anything else you looked at when you did this?
Phil
