Phil:
Didn't check anything else when I did the re-torque as it is a fairly straight forward procedure.
I have non adjustable rocker arms so there is some pressure on the push rods when loosening and re-tightening the rocker shaft.
I pulled the plugs and rotated the crankshaft two revolutions by hand and watched the rockers to make sure everything was functioning as expected before I buttoned it back up.
DonC
