Old 01-22-2016, 04:52 AM
1795's Avatar
1795 1795 is offline
How many miles are on the engine? If you are going to be changing out the cam, do you want to change the bearings as well? I do not think that you can change all of the bearings with the motor in the car.
If you are able to get the correct angle with the engine in the car and the hood and radiator removed, you may want to also take into consideration the impact of the nose length getting in the way of the cam shaft installation. You cannot climb up on it like some cars and trucks, and there is no way that you can install the cam shaft through that narrow cone.
