just a bit of a update i have started to lay the floor on this trailer ive decided to hold the alloy floor down with button head bolts so that means about a 100 or so holes to be drilled and tapped done 20 so far lol. while i had a couple of extra hands today i have temp hung up some of the cladding so i can pre drill it for when it goes on proper .
mounted the winch that will raise the rear loading ramp we hooked it up too a temp battery and it works great . the ramp is off at the moment for better access into the trailer while the floor is going down .
all the suspension is bolted in place and the wire for the 4 wheel electric brakes has been run and secured . hopefully another day working on it tomorrow will see the floor all bolted down .
cheers dean
a cobra is a passion anything else is just a car
i dont care what the question is .. The answer is more power!!!
