Old 02-06-2016, 01:45 AM
Ron61's Avatar
Ron61 Ron61 is offline
That could have damaged the battery also, so be on the look out for that. You said that you pulled the battery cable. You should install a battery cut off switch which you can just turn and it cuts off all power to everything which is much faster and easy than taking a battery cable off. I saw one solenoid stick because of the contacts melting and sticking together but this was one of the old original type. Hitting the starter with a hammer in this case would not have helped as it is going to try to run as long as there is power to it.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
