Originally Posted by Mark IV
Notice that the 289 McCord tank does not have an outlet for the radiator hoses but is just an "expansion tank" unlike the Lincoln tank which has the hose outlet for the upper radiator hose.
That's the modification work that my radiator guy has to do. I removed the outlet on the bottom so he could seal it. Then, he has to remove the big right side inlet and attach a plate and 5/8" nipple. The collar for the cap has to be removed and turned 90* so the overflow is at the rear. Finally, there is the 5/16" inlet that needs to be attached to the front of the tank. The overall shape of this tank is correct, but there is a lot of work and modification needed to make it look like a Cobra tank.
