  #59 (permalink)
Old 02-07-2016, 04:12 PM
Richard Cowart Richard Cowart is offline
Originally Posted by Dimis View Post
Thanks Richard,
I'm curious about the number specs on your cam?
Do you mind sharing?
Sure. And, I am just reading off the form that Comp Cams sent. I hope that when I post this the text and numbers do not readjust where they are scrambled. Hope this helps and I certainly cannot decipher this.
Gross valve lift: Intake 0.649 Exhaust 0.633
Duration @ 0.006 Tappet lift Intake 297 Exhaust 318
Valve Timing @ 0.050 Open: Intake 15 Close: BTDC 47 ABDC
Exhaust 64 BBDC 8 ATDC
Specs for cam installed @ 106.0 intake center line.
Intake: Duration @ 0.050 243.0
Lobe Lift 0.3690
Lobe Separation 112.0
Exhaust: Duration @ 0.050 252.0
Lobe Lift 0.3600
Lobe Separation -------
Grind #: FB 13051R/3151R HR112.0
Part #: 33-999-3
Richard
