Originally Posted by Paintwerks
Ben, for what it's worth, I have an issue with my Speedhut speedo. On two separate occasions, while cruising along, the odometer has climbed like a winning slot machine for no reason. I used to have 120km. Within a minute or so, I had just over 200km!
Need to sort it out. Not sure if it's the wiring or the gauge at the moment.
My VDO speedo does the same thing when the sun is on it on a hot day.
Phil took a photo of us doing 200Km/h going down the Eastern on the way back from Barwon Heads last week.
I not sure whether its electrical/electronic or mechanical - I suspect mechanical as I got the gauge faces re-printed in a classic look. I think the needle is not returning when its hot due to rubbing on the face etc. Will get it fixed one day.
Hope you fine the problem with yours. You too Ben, Cheers Gregg
