Old 05-08-2002, 05:11 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Snake,
The Hinge Plate Nightmare.
Now it becomes clear!
Everything does plug into the column, BUT you need to hook up the 3-way switch as mentioned above. This is what turns on the parking lights and headlights. Middle posistion is off, Up is headlights, down is parking. The "Column" is actually in the middle of the circuit.
I think Petek is the one that explained this in his post. Your hi-beam will work off the switch on the column, same as factory set up.
Now, when it comes to door alignment...call me. I can save you at least one 12 pack for fun instead of aggravation. We paint all body's off the frame, BUT it takes some very serious preperation and alignment to do this. It IS worth it and it WILL save you hours and hours down the road.
I wish I could get this blankety blank computer to work right. I'd post pictures of the harness to the column, to the dash.
Snake, You must come to the DVSF ! This is a must! You will learn more, see more, and experience more in three days than you would with a 3 year degree of Cobra building!
740-852-5280
DV -- 300 Cobras and 1 "Snake" is NOT enough! Are you registered?
