Hi Guye,
I'd say you will be needing the info that relates to the AP set up, so I've dropped in the following info directly from the current owners manual.
Track ‐ (15” Street Tyres)
For 15” tyres such as Mickey Thompson Sportsman S/T we recommend a starting cold
temperature of 35 psi, but re‐check immediately once they are hot.
Hot pressures should be 40 psi as a baseline.
Adjust from there to suit.
Shock Firmness Adjustment ‐ Track
We recommend initial settings of 12 on the front and 9 on the rear.
Adjust to suit.
I'll actually send you those pages...there's a fair bit of info on all of the various tyre size choices/street use/track use etc., but the bit I've posted above should give you the info for what you are doing and with the tyres you have.
Warren.
