Old 02-18-2016, 10:09 PM
stephen low's Avatar
stephen low stephen low is offline
Currently have 14" mufflers in the back corners. Both mufflers were panel beaten to fit so not good. Don't know but doubt these are high flow jobbies so pretty good at sound deadening.
Essentially one hot dog will go into each back corner and being so small will fit a treat, the second dogs will be located just in front of the diff and the pipe work will be high near the lower suspension arm pivot to keep the exhaust as elevated as possible.
Using two pair of hi flow dogs to compensate for the reduced noise reduction capacity of these compared to the 14" mufflers.
And an interesting vid Mike, I too would have sworn big HP loss with the bashing, even early on.
slowy
