  #63 (permalink)
Old 02-20-2016, 07:23 AM
RockBit's Avatar
RockBit RockBit is offline
Cobra Make, Engine: ERA #812 427/482 FE
Originally Posted by Detroit Bill View Post
To the OP you want to get with Brent of the gearing. This will have a cam in it. That cam will not like low rpm. How low is low is the question and Brent will know.
My only other suggestion is the speedo. I would get the electronically driven speedo. It is driven by the speed sensor that comes with the TKO. The cable drive unit is a POS. If you are going for authentic this might be an issue but I thought I would throw it out there for what it is worth.
Good luck!
I spoke with Brent and he endorsed the 3.54 gearing for my setup. I then made the change with Peter. I'm still thinking about your suggestion on the speedo.
The body will be mounted to the chassis next week.
Thanks for the suggestions.
Chris
