Old 02-20-2016, 09:28 AM
Bill E's Avatar
Bill E Bill E is offline
Two problems with mounting my top to a deferent car. the CR is not as symmetric side to side as our car so one side is up higher and the flange over the back of the body would have to be cut and fit. windshield angel would have to be changed to fit the top . The header is made in the top and uses a single clamp in the sinter that pulls a cable that is attached to the windshield side pillars that bolt the windshield frame. The side windows and tee top swing up together and the door opens normally.The deck lid is removed from the car so the hatch lid would have to be fabricated to fit what ever car was used. When installed this top is water tite. and removable. I started with a Mr Bruce top. Should have stopped there. All the hinges are custom and have to be fabricated from stanless You cant bye them I tried. I have build hole cars faster than I can do this top. if you wont one on your car it would be in the 15 K range. Mr Bruce,s top is moor flexible in what it will fit. and a good bye.
Bill Emerson
