The closer to the exhaust port the better.
To prevent moisture from damaging the sensor insure that it's mounted 90 deg or less to the vertical. Less than 90 deg will create a sump that will collect moisture and ruin the O2. Particularly if you're going with a wide band sensor.
DonC
