I have been through a myriad of started issues. The culprit was with a Bellhousing aligned too far toward the passenger side of the car. I think I have that sorted out, but still can only use a Robb MC starter which had the best alignment with the new Bellhousing. If you get one or any after markets, double and triple check the clearances. I would also get the pinion support as over time most starters seem to get a little sloppy. If I had a choice, I would run the dynaforce, however, it would not align enough to get good engagement with the flywheel. Good luck with you selection and feel free to message or call me on my starter woes which I think (crossing my fingers) are all sorted out.
Phil
