Anyone go with a thicker steering wheel?
The wheel on my new BDR Cobra is period correct but very slim as you may know. Even with driving gloves it can be a handful in quick cornering. Im keeping the OEM wheel but having a thicker wood wheel installed but with the same diameter. It has the identical 3 spoke set up as OEM so it keeps a proper appearance. Have any of you done this and found it improved the turning drivability? Thanks
Your ride should not be to get from point to point. It should BE the point!
